Engine died when put in gear
Old Jun 3, 2019 | 09:56 PM
SCblazer71's Avatar
SCblazer71 is on a distinguished road
Default Engine died when put in gear
Started up and when I put in gear it just instantly died. Now it will not even attempt to crank in park or neutral. Fuses, relay, battery are good. All lights work, radio, all accessories. Need advice. Ignition control module? Switch? Thanks
Old Jun 3, 2019 | 10:57 PM
GeorgeLG's Avatar
What year is your blazer?
Does anything malfunction in the key on position?
George
Old Jun 4, 2019 | 06:42 AM
SCblazer71's Avatar
George
2000 4.3 4×4
Everything is normal except it wanting to turn over.
Old Jun 4, 2019 | 08:04 AM
GeorgeLG's Avatar
When you turn the ignition to the start position does 12v appear at the crank fuse (10A) in the under hood fuse box?
George
Old Jun 4, 2019 | 09:13 AM
SCblazer71's Avatar
Yes it has.
Old Jun 4, 2019 | 09:24 AM
GeorgeLG's Avatar
Then your ignition switch is good or at least the start position portion is.
Lets go to the other end. When you turn your ignition switch to the start position do you have 12V on the purple wire connected to the starter?
George
SCblazer71
Sep 24, 2019 11:32 AM
Chris82
Apr 26, 2017 04:19 PM
slagburger
Feb 13, 2012 04:55 PM
mjhoffman48
Mar 1, 2011 12:10 PM
shepk-5
Jul 9, 2010 11:59 PM
