Engine oil lines
Old Jul 30, 2013 | 05:57 AM
dhirt's Avatar
dhirt is on a distinguished road
Default Engine oil lines
Hi,
I recently replaced my engine oil filter lines. The job was a bit messy, but not a big problem. To remove the end from the engine, I had to lift the engine a little bit. But no need to remove the engine mounts.
On the cooler side, where are two round plastic covers. These cracked at the installation. Not completly, only one sharp crack. It is still round. Hope you understand what I mean.
For what is this black cover? Is it only a dust cover or is his job to prevent the blue retaining clip from falling out?
If its to prevent the clip from falling out, I think my cover is now not solid enough. But if its only a dust cover, it should be fine.
I tend to think its a dust cover, since some older lines don't have them. (see last picture) But I'm not sure... Do you have any idea?
Regards,
Dominik
Source of the pictures: How To Fix An Oil Leak: Replacing Oil Cooler Lines In A 1999 GMC Jimmy
Attached Thumbnails Engine oil lines-001.jpg   Engine oil lines-002.jpg   Engine oil lines-003.jpg
Old Jul 30, 2013 | 09:06 AM
spittybays
Guest
Posts: n/a
Think you are correct, those little fins tell me it's not meant to seal anything, just a retainer. A little electric tape should do you just fine.
Old Jul 30, 2013 | 05:28 PM
cleburne red's Avatar
Mine doesn't even have those little deals. X2 on them being a retainer
Old Jul 30, 2013 | 06:54 PM
Spree's Avatar
Spree is on a distinguished road
I doe's both job's but shouldn't be a problem...I wouldn't worry about it. Those clip's aren't going anywhere.
Old Jul 31, 2013 | 03:22 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
The clips are solid. I broke one of the plastic covers when I did my oil lines a couple months ago. If the clips are seated properly they won't come out and won't let your hoses back out of the fittings.
Old Aug 5, 2013 | 05:48 AM
dhirt's Avatar
Thank for your replies. In this case, I will leave the things as they are.
cahlersmeyer
23
Nov 10, 2011 09:23 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Hntr36
Mar 21, 2010 01:53 PM
