engine swap
Old Jun 28, 2011 | 03:52 PM
coolasice's Avatar
coolasice will become famous soon enough
Default engine swap
ok, my engine is dying(bearings) and i want to swap in a used one from a silverado, what exactly needs to be changed over when doing this and what years are compatible? ive heard of different timing covers on newer models. ive searched but noone goes into details...
Old Jun 29, 2011 | 10:17 AM
coolasice's Avatar
will a 2003 blazer engine work if I swap the intake/exhaust manifolds and drill/tap the knock sensor?
Old Jun 29, 2011 | 04:17 PM
Pretty much. I would use the MFI spider from the '03 as well.
Old Jun 30, 2011 | 05:50 AM
coolasice's Avatar
Thats what the plan is, I just need to find out if it was a 4x4 or not. If not I'll have to swap the oil pan and pickup tube I think. But other then that it should be pretty simple.
Old Jul 31, 2011 | 05:58 PM
coolasice's Avatar
WOOHOO! Swap is done, what a complete Bitch that was.... finished this morning and drove it home...2003 blazer into a 2000... had to swap all manifolds and had a hell of a time getting everything back into place... runs like a top!(after 3 attempts at timing it).. not a single check engine light, doesn't miss, but I do need to remove and clean the IAC valve... and get a new clip for the cruise control... holay crap the oil pressure is almost double the old engine at idle and cruise... awesome
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
ronnyrum1
Engine & Internal
Dec 11, 2005 11:34 AM
billybird
Jul 20, 2005 11:17 AM
