Engine won’t start
Old Aug 31, 2019 | 07:33 PM
Small Arms Collector's Avatar
Small Arms Collector is on a distinguished road
Best bang for you buck in my opinion is stick with all AC Delco replacements. Fairly priced on RockAuto and pretty much anywhere else.
AC Delco iridium spark plugs part number 41-993
AC Delco distributor cap part number D328A
AC Delco distributor rotor part number D465
I installed these during a tune up a little over 5 years ago and they've given me no issues at all, still in the truck now.
Only reason I would ever replace the wires is if one of them is chafed through, arching, and cause you issues. On these engines I personally don't think there's much to benefit from throwing on a set of MSD wires or anything like that. Factory AC Delco wires are 8mm if I'm not mistaken, and the MSD's are 8.5mm, not much of a jump there...
Same with the coil, I wouldn't bother unless the original dies or splits open and starts arching...
And if either of those were to ever give out, I would still just replace them with AC Delco stuff.
I’m having a no start issue on mornings after it rains, it starts after it dries out though so moisture is getting in to the system somewhere, I replaced the distributor cap and rotor a few months ago and had them checked again today so I know that’s not the issue, so that means it has to be either the coil or the wires. Not sure which so I’m just replacing them both just to be sure. Not able to find it on my own though I did take it in to the mechanic today and he said the wires were pretty shot anyway, though he wasn’t sure if that or the coil was the problem.
Right now I’m thinking of AC Delco Iridium spark plugs, NGK coil, and Standard Motor Products “Blue Streak High Performance” 8.5mm wires. I selected the non AC Delco stuff due to lower price and better warranty. I have not actually ordered anything yet though, I just want to make sure I’m not shooting myself in the foot. Thoughts on NGK and Standard Motor Products?
Old Aug 31, 2019 | 09:56 PM
I've always used NGK plugs on my Toyotas in the past (91 Pickup, 02 Corolla, 06 Tacoma), and on recently acquired beater 98 Saturn SL2. Have never had an issue with them that was their fault (the 02 Corolla would foul plugs out regularly, but with 320k on the original engine, it also burned a quart of oil with every gas fill up lol).
Can't say that I've ever used Standard Motor Products parts though.
Old Aug 31, 2019 | 10:48 PM
ChuckNTruck's Avatar
Just stick with factory AC Delco stuff as Blazin red has said. Most of the high performance wires are just a waste of money and you will not see any performance gains on a 4.3 The same goes for the coil.
As to the spark plugs, if you don't mind changing them every 30-50k miles just get some good NGK or ACdelco copper plugs and gap them correctly. Iridium plugs are good for longer mileage without needing to be changed, but usually come with a hefty price tag.
chevy2
Dec 30, 2017 01:12 PM
wdg198111
Feb 9, 2015 01:57 PM
sunnyblueskies
14
Sep 21, 2011 07:27 PM
zeedeevil21
Apr 2, 2009 07:21 AM
smplgrn
13
Jan 23, 2006 09:02 PM
