Evaporator Case Disintegrating
Old 07-22-2013, 07:25 AM
bluefleetwood's Avatar
bluefleetwood is on a distinguished road
Default Evaporator Case Disintegrating
I have a 95 GMC Jimmy and I've just noticed my Evaporator Casing on the fire wall is falling apart. Its all dried out and literally falling to little pieces. Are these parts still available and what is involved in changing them out?
Thanks
Old 07-22-2013, 07:34 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
there is an exterior case that does this, dont worry about it unless it is in fact the inner most case, which will leave the aluminum evaporator core exposed.
But as far as the case goes, join the club lol. They all do this
Old 07-22-2013, 07:38 AM
Thanks you sir, Should I just peel the rest of it off so no pieces fall where they shouldn't?
Old 07-22-2013, 07:42 AM
if you want, it wont hurt either way. It will just fall out on the road. Worst case is the exhaust but it wont be set ablaze or anything. Just melt alittle till it is small enough to fall out
Old 07-22-2013, 08:13 AM
Is it a pain in the a.. to replace? Does the Evap have to come out?
Old 07-22-2013, 09:13 AM
Twip's Avatar
dont bother replacing it. it really isnt needed as long as the inner case is complete. the outer case is just sorta "extra." the best i can figure is that GM put it there to act as a heat shield, and then later found out they dont really need it as long as the A/C is working properly. plus, if you ever have to change the Blower motor or change the heater core, you have to cut parts of it out and throw them away anyway. so why bother.
Old 07-22-2013, 05:41 PM
Thumbs up
You guys are the BEST!!!!!
Thanks a lot!!!!!
mattj3773
04-20-2010 09:25 AM
steveblazer
06-10-2009 06:55 PM
JediKnight2
04-04-2008 12:44 PM
junkmonkey
08-24-2007 12:32 PM
okmomw/blazer
06-29-2006 12:56 PM
Quick Reply: Evaporator Case Disintegrating
