extra backup lamps
Old Sep 28, 2008 | 09:10 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default extra backup lamps
If I wanted to hookup extra backup lamps the easy way, how many watts can I run off the backup lamp wire in my trailer wiring harness. I dont plan on using my hitch and my 7 wire harness is just a group of wires taped together.
Old Sep 28, 2008 | 09:20 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Default RE: extra backup lamps
Not sure how many watts you can have but I tapped into my headlight for fogs so they would come on with my daytimes and they would just flicker, they were only 55watts too. But I hard wired them and I believe that would be a better way to go then just, cutting and taping wires togther from a trailer harness.
Old Sep 29, 2008 | 09:38 PM
neo71665's Avatar
You will cook the wires if you try to hook anything bigger than 3 watts to them. You have to put it on a relay to turn on with the back up lights. As with most wiring its about maxed out at what it can carry from the factory and you can't add much more.
Old Sep 30, 2008 | 07:55 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
I have a set of 55W halogen back up lamps hooked into my trailer wire harness had to hook up a manual switch. The set is about $20 at Pep Boys
packrat1969
Jul 18, 2012 11:40 PM
kccowman
Dec 7, 2009 08:50 AM
Shamrock3
Jun 18, 2009 06:22 PM
flyinbrad
Jul 6, 2007 07:05 PM
Shamrock3
May 30, 2007 01:58 PM
