Fan blade touching shroud
Old Aug 30, 2021 | 06:23 AM
puttster's Avatar
Default Fan blade touching shroud
After getting a new radiator i intermittently hear this ticking. when I move the shroud the ticking gets louder or softer. Blade is hitting on the passenger side. What can I adjust to fix the problem?
Old Aug 30, 2021 | 08:36 AM
The first thing you should check is the motor mounts. They are notoriously bad, and are probably broken.
Old Aug 30, 2021 | 08:44 PM
Fozzy's Avatar
Fozzy is on a distinguished road
How's your water pump? when they get really bad, the bearings will allow slop
Old Aug 31, 2021 | 08:05 AM
LannyL81's Avatar
Also make sure the fan bolts are to the fan clutch, fan clutch to the coolant pump.
Could be that the fan shroud was not put back into place....there are three bolts across the front, then two on each side. The bottom half of the shroud is supposed to snap into place...which on mine is a bit difficult to get it to do so.
Later,
Old Aug 31, 2021 | 09:31 AM
puttster's Avatar
I can see where the point of contact is, what say I get some shears and cut the shroud there?
Old Aug 31, 2021 | 09:35 AM
Better to fix the root cause.
Old Sep 1, 2021 | 02:24 PM
El_Beautor's Avatar
Agreed. If the sound started after you replaced the radiator, it's most likely that the fan shroud isn't quite seated correctly. The bottom half can be difficult to get snapped in, especially if there was any debris in the channel when you re-installed it. I'd suggest removing the fan shroud, cleaning the channel at the bottom, and re-installing it to make sure it clears the fan properly. This will also make sure the fan is centered in the opening to maximise airflow through the radiator. Too big of a gap can lead to reduced airflow through the radiator.
Old Sep 1, 2021 | 04:06 PM
puttster's Avatar
I see the three screws on top, is there a trick to raising it up?
Old Sep 1, 2021 | 04:41 PM
Is it hitting the top of the shroud?
Is your rad support pushed back any?
Old Sep 2, 2021 | 06:38 AM
puttster's Avatar
Fan touches on the side. I wanted to raise the shroud up and reposition it in case that was the problem.
It's very possible that the radiator support has been damaged. I've been involved in three front end accidents. However everything was okay before I got the new radiator so I'm thinking there was an issue with the install.
Viggo
Apr 25, 2020 02:25 AM
redneck999
May 11, 2017 08:05 AM
toxikchevy
Engine & Internal
Jan 26, 2010 04:27 PM
upblazer95
Nov 16, 2008 03:20 AM
noom14921992
Apr 27, 2008 02:23 AM
