Engine Fan or Electrical Fan
Old Apr 22, 2020 | 02:16 PM
Viggo's Avatar
Viggo is on a distinguished road
Default Engine Fan or Electrical Fan
Quick question. I have a '71 Blazer with a 454 that overheats when not moving. I'm working on getting it back on the road and want to eliminate this problem. Should I go with an electrical radiator fan in conjunction with the engine fan. Or should I have just the electrical fan? Can the electrical fan be tied the thermostat or will I always have to switch it on? I don't like the idea of having to flip a switch each time I drive it as I know I will forget? Looking forward to your advise!
Old Apr 22, 2020 | 10:42 PM
I think it is pretty standard set up to have an electric fan with a relay controlled by a temperature sensor.
Does your mechanical fan have a shroud? Adding a shroud can make a big improvement if you want to keep things simple. I learned this lesson on my 68 Mustang.
Old Apr 23, 2020 | 10:25 AM
Viggo's Avatar
Hi there, yes the mechanical has a fan and the blazer still overheats when stuck in traffic.
Old Apr 23, 2020 | 11:01 AM
rriddle3's Avatar
Firstly, what have you done maintenance-wise? Thoroughly flushed the coolant system including the heater core? Installed correct amount of coolant mixture? Replaced the thermostat? Replaced the radiator cap?
Old Apr 24, 2020 | 10:27 AM
Viggo's Avatar
Thermostat was replaced. Never thought about replacing the radiator cap. The cap looked newish. Suppose I can give that a try! Thanks
Old Apr 25, 2020 | 02:25 AM
Check and flush radiator too. There is a reason for overheating. Should not be the case - unless you live in a place that has already 90 - 100 F.
redneck999
May 11, 2017 08:05 AM
mrd0t
Performance & Brainstorming
Jan 9, 2011 02:17 PM
tb402
Jul 19, 2010 09:31 AM
toxikchevy
Engine & Internal
Jan 26, 2010 04:27 PM
noom14921992
Apr 27, 2008 02:23 AM
