Flashers not operating properly
Old Feb 13, 2021 | 12:17 PM
Argon's Avatar
Argon is on a distinguished road
Default Flashers not operating properly
I'm working with a 1995 blazer.
Both the left and right blinkers flash rapidly. I'm pretty sure its the flasher relay, but not 100%. I couldn't find any other post about someone experiencing that. Also, I have been finding conflicting info as to where the flasher is. Can anyone confirm if its behind the glove box or under the radio? Its negative degrees out here and I'd rather not go on a wold goose chase lol thanks!
Old Feb 13, 2021 | 01:25 PM
GeorgeLG's Avatar
There are turn and hazard flashers which are both listed as “Convienience center behind center of I/P”. Besides those two flashers, the Turn/hazard switch is also involved. Under what conditions does this happen or not happen?
George
Old Feb 14, 2021 | 12:21 AM
Argon's Avatar
My hazards just don't work at all. And the turn signal just blinks rapidly when I click it on. Left or right, doesn't matter. I've verified I don't have a bulb out. And it is every time I use my blinker
Old Feb 14, 2021 | 10:19 AM
GeorgeLG's Avatar
Check the Stop-hazard fuse 1, 15a in the I/P fuse block for the no hazard problem.
If you are certain that all of your bulbs are working then next up is the flasher(s). Check the hot side voltages to the flashers while your in there.
If that doesn’t do it then you need to check some voltages and or the turn/hzd switch. let us know.
George
Ryanmatt135
Jul 20, 2025 04:32 PM
tomthowell
Aug 26, 2015 03:28 PM
piscespokerbrat
May 25, 2012 01:00 AM
TylerNormand
Oct 2, 2010 12:21 AM
banshee386
Jun 13, 2010 03:42 PM
