Fluid rear tire
Old Jan 21, 2010 | 10:18 PM
dacop's Avatar
dacop is an unknown quantity at this point
Default Fluid rear tire
Hey Guys,
I just noticed some fluid coming from the rear tire (back of it from the rim). Its on the ground and all over the back of the tire. What could this be from?
Old Jan 21, 2010 | 10:31 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
Originally Posted by dacop
Hey Guys,
you could have a brake fluid leak if it was bad enough. is it just on one side or is it on both
Old Jan 21, 2010 | 11:01 PM
NVANZEE's Avatar
either brake fluid or gear lube
Old Jan 22, 2010 | 06:35 AM
x2.
A leaking brake line, wheel cylinder/caliper leak, or a bad axle seal.
Old Jan 22, 2010 | 02:51 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Just want to add. If it has a smell that you can smell all the way up by the front of the car, it's probably Gear oil from the Axle. Gear oil has a smell you can't miss.
Where brake fluid is much mellower. Hope it's Brake fluid, easier to fix.
Discs or Drums in the rear?
If you have drums, do you notice that tire locking up when you brake? Brake fluid on Brake shoes get very grabby.
Old Jan 22, 2010 | 03:06 PM
papacope's Avatar
I had the same problem a few years back and it was just a bad brake cable.
BrinkDiamond
Mar 2, 2014 03:50 PM
Gnfanatic
Jan 23, 2012 07:15 AM
eknox327
Mar 17, 2011 06:22 PM
DaleA
Jan 13, 2009 08:50 PM
Blazertrish66
Apr 29, 2008 07:54 PM
