FOUND a code scanner that WILL work on a 95
Old Apr 13, 2008 | 12:14 AM
95LS's Avatar
95LS is an unknown quantity at this point
Default FOUND a code scanner that WILL work on a 95
as many of you might have read i have been looking for a handheld code scanner that will work on a 95. i finally found one. i was looking at the equus 3140 but after calling them they told me it will no t work. Actron CP9190 will work. i looked at the pdf of their manual and it is listed as a supported vehicle. they said some 95's use a 16 pin OBD II connector but it is OBD I compliant (im guessing thats why the equus wont work for some strange reason if it has the capability/connectors for both OBD I and II i dont see why it wouldnt). i wish the equus would work i have a compression/ fuel pressure tester, vaccum guage, LED timing light (even has idle RPM's and the timing advance on screen) i will buy their fuel pressure tester as well i havent had any problems with them so far. looks like im going to have to settle for actron. but at least i will have one when i need it. has anyone used any other handhelds on their 95's ? please post somments about them.
Old Apr 13, 2008 | 11:55 AM
95_4door's Avatar
95_4door is an unknown quantity at this point
Default RE: FOUND a code scanner that WILL work on a 95
Any of actron's scanners that are obd2 will work. They have been programmed to work with the obd2 transition. We sell them at work and I have tried most of them on my truck and haven't had any problems.
Old Apr 13, 2008 | 11:27 PM
95LS's Avatar
that makes me feel a little better. thanks for the imput. can u get me a discount ?
bizzs
Nov 4, 2012 02:11 PM
grantd
Jan 17, 2011 01:34 PM
TimmyBlaze
Dec 23, 2010 11:01 PM
old skool luvr
Apr 19, 2010 11:13 PM
DaveHearne
Feb 25, 2010 06:46 PM
