Front axels ?
Old Jan 24, 2008 | 03:22 PM
1blkblazer422's Avatar
1blkblazer422 is an unknown quantity at this point
Default Front axels ?
On a 2001 Blazer I purchased I noticed that it had a bad humming noise and I found the problem to be a bad wheel bearing. As I was going to put the tire on I noticed fresh axel grease spitting out on the control arm. I pulled the other wheel as well and that also had fresh axel grease on it. I have been having 4wd issues with the vehicle as well and just installed a new transmission. It seems like it started doin this when I put the vehicle in the air to test what wheel bearing was bad. Why would the axels suddenly starts spitting out grease? Thanks
Old Jan 24, 2008 | 04:44 PM
Chevy Lover's Avatar
Default RE: Front axels ?
If you clean up the grease you will probably find that the c/v boots are split. There are boot kits available to replace your torn ones. The kit also contains a new package of grease.
N3ROST4R
Aug 27, 2012 11:01 PM
BERN83
Jan 11, 2012 12:51 PM
larryou812
Feb 25, 2011 07:04 PM
97CountryJukeboxLt
Dec 14, 2010 07:31 AM
ericthughes
Apr 24, 2010 09:24 AM
