Front driveshaft hitting motor!!!
Old Dec 5, 2011 | 09:51 PM
  #21
I'm thinking it has to be something amiss with the motor mounts. I'm not exactly sure on the s-series trucks, but I know quite a few older vehicles have the motor offset to one side.
How does the fan shroud to fan fit look? (2nd time)
Old Dec 6, 2011 | 01:02 PM
  #22
chcknugget's Avatar
chcknugget is on a distinguished road
OK, more info:
The fan is perfectly centered in the fan shroud. Advance Auto originally provided me with the wrong part, I exchanged for the correct mount (same part #, different box) that is supposed to go in there and it is the same height as my original mount.
Is the 'knuckle' of the u-joint supposed to be in front of the bellhousing? I might be able to move the motor back about 1/4". The mounts on the motor are adjustable front to back- I have to check the holes on the crossmember for room tho.
Old Dec 7, 2011 | 10:20 AM
  #23
chcknugget's Avatar
Does anyone have a pic of their u-joint to motor clearance?
I bought some new front shocks, hopefully these will get ride of some of the bounce.
Old Dec 7, 2011 | 05:35 PM
  #24
Sorry, can't help ya on the picture; mine's a '98 and has a slip joint at the transfer case end of the prop shaft.
Old Dec 7, 2011 | 05:44 PM
  #25
If I'm not mistaken, the u-joint you see in the picture he posted is up at the front diff.
Old Dec 7, 2011 | 10:11 PM
  #26
chcknugget's Avatar
Correct, I'm looking for the u-joint near the front diff...
Old Dec 12, 2011 | 08:24 AM
  #27
chcknugget's Avatar
I installed a new trans mount, and there is about 3/8" between the front driveshaft and the motor. This still seems awful close. How much clearance should there be? Could someone snap a pic?
Old Dec 12, 2011 | 08:56 AM
  #28
3/8" should be sufficient considering the mounting used for all of the components.
Old Dec 13, 2011 | 08:21 AM
  #29
chcknugget's Avatar
Many thanks, the driveshaft no longer hits. The transmission mount was bad, and this was compounded by bad shocks.
gitch93
Jan 23, 2013 04:51 PM
JGarr
14
Mar 6, 2007 07:14 PM
Blasir
Feb 7, 2007 09:07 PM
Blasir
Oct 12, 2006 11:32 PM
trudynosports
Dec 13, 2005 09:40 PM
