Front driveshaft question
Old Sep 25, 2012 | 05:31 PM
vadatara2's Avatar
vadatara2 is an unknown quantity at this point
Default Front driveshaft question
Are the universals in the front drive shaft (propeller shaft) glued in and need to be heated to be remove like the main driveshaft universals>
04 blazer 4.3 4wd 4 door.
Thanks
Old Sep 25, 2012 | 05:41 PM
step66's Avatar
While I am not familiar with the front shaft joints of an S series as I have not had to change any(yet) My 91 Suburban had those type of joints for both shafts. I would just obtain the correct replacement joints(with grease fittings) and swap them out. Heat from at least a propane torch makes this job much easier! A vise and a press is also handy,search this site,you will find what you need.
Old Sep 25, 2012 | 06:19 PM
abig84's Avatar
probably. if you see like little white plastic things coming out the ears of the driveshaft then yep. gotta burn them out
Old Sep 25, 2012 | 06:32 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
mine is a 98 and they were not glued in just internal lock joints
Old Sep 25, 2012 | 06:35 PM
newguy's Avatar
On my 98b I got mad cuz it wouldnt come out, Then did the shake weight to it and it came off!
gitch93
Jan 23, 2013 04:51 PM
JGarr
14
Mar 6, 2007 07:14 PM
Blasir
Feb 7, 2007 09:07 PM
Blasir
Oct 12, 2006 11:32 PM
trudynosports
Dec 13, 2005 09:40 PM
