Front end knock - but only when backing up?
Hi, bit of a strange one this. When going over rough ground my 99 4dr RHD Blazer has developed a loud knocking sound from the front left side - but only when backing up? I have gotten underneath & grabbed every component I can get my hands on & tried to shake it around but I just cannot find any significant movement in anything? It is quite a loud knocking sound - any suggestions/advice would be appreciated.
Oh - and before anyone says anything, I have checked out the hood hinges & they are fine, I fitted the GM washers to them a couple years ago which cured the knocking/rattling problem I had at the time.
I think I may have found the problem. I went under the vehicle again earlier & found a little bit of looseness in the joint on the front driveshaft at the transfer case end. Does anyone know whether this joint can be replaced on it's own or do I have to buy the whole shaft? Even if it's not the source of the noise I am not happy with play here so feel it needs to be replaced.
The U joints on the front drive shaft are replaceable...if that is what you are referring to.
Be advised if the U joints are original, then they are "glued" in. But not a problem...just apply a torch to the end and watch the glue ooze out of the small hole in the ends. A bit fun to watch...just do not let it drip on your foot.
Then use a U joint press to remove the old and install the one U joints.
Just a little update on my front end rattle that has been bugging me for a long time now - thought i'd share it in case other owners have a mysterious knock from their front end.
I found quite a lot of looseness on the CV joint on the front propshaft, the one nearest to the transfer case. I managed to obtain this joint through RockAuto & it was a pretty easy job to replace. It has made a hell of a difference, a rumbling sound + some vibration I have had for quite some time has finally gone. But - I still had a slight knocking there!
So - put the front end on axle stands & got underneath & went through everything yet again to try to find any looseness. I checked balljoints, CV axles, hub bearings, steering linkage - everything I could think of but found nothing.
Almost at the point of giving up I decided that while the truck was up in the air i'd do an oil & filter change as it was due for one. This is when I had my eureka moment. When loosening the oil pan drain plug I caught the undertray under the engine with my wrench - and it was loose! A couple of the torx bolts holding it on at the back needed tightening. Couldn't wait to go for a drive to see if the noise had gone - and it had!
Just thought i'd share this as a bit of useful information for anyone that has an elusive front-end rattle.
spikell
Oct 13, 2008 10:20 PM
Joey P.
Jun 4, 2007 09:33 AM
