front end noise
Old Sep 14, 2009 | 07:31 PM
deweasefan25's Avatar
deweasefan25 is on a distinguished road
Default front end noise
I've got a 99 blazer ls and when you accelerate hard, I get a "card in spokes" sound out of what sounds like the right front wheel and it get louder as I come to a stop, but after I stop it goes away until, I get hard on the accelerator again. 4WD works fine and there's no vibration, evrything is tight up front and there's no unusual wear on the tires. Does anyone have any suggestions on what it might be?
Old Sep 15, 2009 | 07:44 AM
sparkmehanic's Avatar
sparkmehanic is on a distinguished road
Replace your hub / Front wheel bearing unit, Timken Brand about $100. While you are there, you might as well jump into the upper and lower ball joints and also check your CV joints for play. About $200 in parts per side and good solid piece of mind.
Old Sep 16, 2009 | 04:45 PM
now i've found out that when it makes the noise if i put it in 4wd it stops. what might that be?
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
Chrismacster
Apr 2, 2009 06:57 PM
desertirish
16
Mar 28, 2007 08:01 PM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
