Front passenger hub assembly
Getting a droning sound I believe from the passe ger front, I think the pass side hub/bearing assy is the problem. I have replaced the driver side hub, and upper/lower ball joints a year ago. Would a good test be to turn the hub by hand and see if it grinds, catches on something or not spin freely?
The old hub was grinding, new hub on as quiet as can be.
I've had mine off so many times between replacing both and pulling everything apart to do ***** joints twice, I can have the old bearing ripped off and the new one back on, Blazer back on all 4's, within 20 minutes, no lie... Took maybe 30 minutes last time I replaced a hub because I used a hydraulic lift at work and the lift was slower to get to chest level than just throwing a floor jack under the front :P
cbur307736
05-05-2011 07:27 AM
strad
12-11-2010 08:04 PM
