Front Passenger side moulding help
Old Mar 21, 2013 | 12:57 PM
blazer21230's Avatar
blazer21230 is on a distinguished road
Default Front Passenger side moulding help
Does anyone know what this piece is called and where I can get a replacement? I was in an accident and mine is trashed ( this is a generic picture btw ). Also any ideas on how to replace it? I believe mine is riveted in and I do not own a rivet gun. Thanks for taking a look. Sorry this for a 2001 Blazer LS 4wd.
Old Mar 21, 2013 | 01:38 PM
rexmburns's Avatar
Super Moderator
I believe it is called a "bumper flarette". Good luck finding one I would say check the pick n pulls near you. As far as replacing it you may be able to srcrew it in from the backside or something. I don't have a Z so I'm not familiar with how they attach sorry.
Old Mar 21, 2013 | 02:47 PM
Wow I never would have guessed that part name. I did some searching and you are correct, I also found out that the GM part number is GM1269112. I found it at Rock auto for $35. Thanks for the quick and correct response.
Old Mar 21, 2013 | 03:25 PM
rexmburns's Avatar
Super Moderator
Your welcome. Good luck with the repair!
Old Mar 21, 2013 | 04:30 PM
El_Beautor's Avatar
I'm pretty sure that piece is held on by 2 little bolts (I think 10mm), that are likely completely seized and will break off when you try to unbolt the old one. Since it's trashed it shouldn't be a problem and you can just bolt on the new one.
Old Mar 22, 2013 | 01:25 AM
step66's Avatar
Yes,the little and short screws WILL break when you try to remove them! Been there with all the side moulding swap a few years back!
El_Beautor:fine looking unit for the north country! Butaint your rusty frame!
I hit my frame with a wire wheel and primer about every 2 years-give it the same care a Robert Trans truck gets annually:beaded and painted! All my best!
upmaine
Jul 9, 2012 12:31 PM
huff4
Jun 20, 2010 04:03 PM
S10Blazer
Jan 13, 2010 02:12 AM
Burlisonm
Nov 1, 2007 08:25 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
