front and rear diff question
As stated above, the front diff has drain and fill plugs. The rear diff only has a fill plug, drain by removing cover.
The front diff is filled in two ways: get a hose that will wedge into the fill port or just use the vent hose already there, clamped to the radiator shroud.
The rear requires a hose to fill as well. Be sure to get a new gasket for the rear cover. If the rear cover is really rusty, easier to just get a new cover.
Did this job on my '02 last year. Not a bad job....bit messy, but not bad. Do the transfer case at the sametime. Note: transfer case uses a different lube than the diffs.
Did the front and trans case yesterday... 13 mm drain and 15 mm fill on front(1.3 Qts)..trans drain and fill was a large allen wrench(1.5 Qts ish)...1 1/2 hr labor after clean up...ill do rear next pay day...
6Cyl'erThriller
Oct 15, 2011 06:11 PM
simmonsnick
Feb 5, 2011 05:50 PM
dougg01
Mar 17, 2010 10:49 AM
Brianator99
Aug 30, 2009 06:18 PM
aaron.b
Aug 11, 2009 12:06 PM
