fuel gauge
Old Aug 25, 2005 | 03:33 AM
dblazer's Avatar
dblazer is an unknown quantity at this point
Default fuel gauge
my fuel gauge needle jumps around when Im at 1/2 tank of fuel I was told it could be the sending unit and of just curiouscity I took it to the dealer and yes they told me it was the sending unit, but I dont have $700 bucks to fix it can anyone tell me if its hard to change it, sorry again for my poor spelling
Old Aug 25, 2005 | 12:39 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: fuel gauge
Well, my fuel gauge is messed up, but it's just because it's messed up, not because it's the sending unit. I'd make sure before you invest all that money for nothing.
Old Aug 26, 2005 | 03:30 PM
dblazer's Avatar
your right I was reading the chilton book and there is a way to check the ohms from the gas tank , thanks
Oscar
Old Nov 17, 2005 | 01:44 PM
burcham's Avatar
burcham is an unknown quantity at this point
I have a 98 blazer. And im having kinda the same problem with my fuel gauge...BUT.. my fuel gage works fine up untill you get to half of a tank.. then it stops and does not go past that. So after half a tank, i have to guess on how much gas i really have... Ive seen on all these Forums that peoples gauges just go nuts or just dont work.. but mine does..(up untill half a tank) But i havent seen anyone with my problem.. is it my Fuel Meter..sending unit or the needle its self? i havent check grounding wire yet but just seeing if im missing something?
Old Nov 17, 2005 | 03:47 PM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
My fuel gauge on my '91 is goofy, too, but it just takes setting the trip odometer every time I refuel and then paying attention to the gauge's behavior to get more of a feeling for its idosyncracies in case some time I forget to reset the trip odometer. Luckily, on mine, it acts goofiest during the first half of the tankful, and toward the end, it stays pretty much the same, toward the low end of the dial. It does register as low even though I've only used 13 or 14 gallons, when my manual tells me there are 20 gallons in the tank. But I figure that is good, since it makes me go ahead and fill up before I start putting a lot of stress on the fuel pump with an almost-empty tank. I would not think about replacing the sending unit unless I had to replace the fuel pump and already had the gas tank out.
You might do a search on this in the forum, as it has been discussed before, and seems to be a common problem.
Old Nov 17, 2005 | 06:43 PM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
ORIGINAL: burcham
Sounds like the float is stuck...not really easy to check, you have to drop the tank, remove the slide lock for the pump housing on the tank, remove the whole unit, and check for proper movement, or...deal with it
Old Nov 18, 2005 | 03:35 PM
Hanr3's Avatar
ORIGINAL: drkmelvin
ORIGINAL: burcham
Or replace the sending unit. Most cases where the fuel gauge is acting goofy is related to a fualty gas gauge sending unit. The cure, replce it. Since you have the gas tank out, replace the fuel pump, the screen, and the rubber gasket on top. Also clean the tank out, and make sure the rust isn't too bad. Clean the rust off too. IF you have holes, JB Weld works good to patch them.
grayman63
Jul 17, 2013 01:56 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
