Fuel Gauge 2000 2dr Blazer
Old Dec 12, 2009 | 10:56 AM
Norman's Avatar
Norman is on a distinguished road
Default Fuel Gauge 2000 2dr Blazer
My fuel guage does not work. Any thoughts on the problem and possible fix?
Old Dec 12, 2009 | 10:57 AM
Common problem. Search for "fuel+gauge" and you should turn up quite a few results.
Bottom line is that the sending unit is the likely culprit.
Old Dec 12, 2009 | 11:15 AM
Norman's Avatar
Thanks. Seems complicated and costly. I'll continue to use the odometer and ignore the fuel gauge. I appreciate the help.
Old Dec 14, 2009 | 08:46 PM
deviantsyndicate's Avatar
deviantsyndicate is on a distinguished road
it sounds like to me that your sending unit has went out have replaced plenty of them
Old Dec 14, 2009 | 10:05 PM
AJBert's Avatar
Mine has been out for at least the past four years. I don't see any reason to fix it until I need to replace the fuel pump. Just keep using the trip odometer and you'll be fine.
Old Dec 21, 2009 | 11:26 AM
Minipicard's Avatar
Minipicard is on a distinguished road
Hi guys, I'm having this same problem but am about to go on a cross country road trip... so having a heads up on when I'm running low on fuel is going to come in real handy especially with the variations in MPG caused by elevation, load, traffic, etc...
Is there a way to fix this issue on the cheap? Any MacGuyver fixes?
Also, any tips on prepping my Blazer for cross country travel would be appreciated!
Thanks!
Old Dec 21, 2009 | 12:02 PM
Fill up every 100 miles for a bit until you get a handle on the fuel usage and then extend it.
Old Dec 21, 2009 | 05:05 PM
Minipicard's Avatar
That's going to be especially painful given the variability of gas station availability in some states... I guess this is one fix I'll just *have* to make before the trip.
I understand it's a common problem on blazers, could I get an idea from some of you that have had it done how much it costs to fix?
Also.. if I bought one of those boxes that talks to the brain box directly would I be able to derive from that info how much gas is in the tank? Or are those stats dependant on the broken "sender" bit in the fuel pump?
TIA!
Old Dec 21, 2009 | 08:45 PM
They are not dependent on the fuel gauge, but they are not all that accurate either.
You could try just replacing the fuel level sending unit which is available separately and costs a lot less than the whole pump. Of course, with the issues that fuel pumps have in these trucks and the fact that the work to replace the sending unit is the same as the work required to change the pump... That is just a call that you are going to have to make.
rxjimmy
Dec 15, 2014 07:39 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
