fuel leak
i got a 1996 chevy blazer with a fuel leak right at the tank im not totally sure if its the line that connects to the sending unit or the sending unit itself
wheres the leak at again? the tank it self? front? rear?
The fuel leak is from the front of the fuel tank. Hopefully i can get pointed in the right direction for this thing
The blazer i just bought has a fuel leak also... what i found was the vent leaking when i over filled it.. My tank is metal so it is replaceable not sure about yours..
good luck
good luck
The leak is probably from the vent valve (part of emissions system). It's common for the vacuum hose to become detached when removing the tank. It's also possible to break the plastic tube the hose attaches to. If the leak is coming from the front it is either that or a rust hole. Also, be advised, the fuel lines run along the top of the frame and don't get the gunk washed off over the years and eventually rust out. If the leak happens only when the ignition is on, you have a hole in your fuel line. My "96 developed a leak aft of the fuel filter after service. I bypassed the rusted line with high pressure rubber line from Car Quest.
agreed, the vent valve at the front, mine was leaking. needed a new gas tank since the plastic ones are made in a way where you cannot replace the valve ( atleast i couldn't figure out how ) if its a metal tank it should just unscrew
BubbaBrooks
05-18-2011 08:38 PM
abadinalbany
06-01-2009 08:27 PM
