Fuel Pressure
Old Jul 1, 2011 | 03:02 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default Fuel Pressure
Long time no talk. Well not holding fuel pressure. After letting the blazer sit for awhile i have to turn key on and off 2 to 3 times before it starts nicely. Thinking check/one way valve, my question is can you buy just the valve or do i need a whole new fuel pump?
Old Jul 2, 2011 | 12:47 PM
blazerblack's Avatar
blazerblack is on a distinguished road
It could be the fuel pressure regulator, or a small fuel leak.
Old Jul 14, 2011 | 11:37 AM
Numba1Sean's Avatar
yea i just dont want to buy a fuel pump and have that not be the prob. so many things it could be.
Old Jul 14, 2011 | 12:24 PM
taabjb2010's Avatar
taabjb2010 is on a distinguished road
when taking off the intake manifold do you have to take off the ac bracket and pulley in front of the radiator does that have to come out for when taking the intake manifold off. please help me I am lost. The job look easy but it is more messed up than before I did label everything I took off.
Old Jul 14, 2011 | 12:44 PM
Fivspeed's Avatar
Fivspeed is an unknown quantity at this point
Originally Posted by Fivspeed
By "front of the radiator" I assume you mean behind the radiator, as in the compressor and bracketry? If so, then yes, or at least I took mine off. There are pics somewhere (sorry, busy at work) that show the location of each bolt or nut that needs to be removed. I believe 2 bolts and one nut in front, one bolt on the lower left, hard to see, and two more underneath. If you can find the pics you'll see what I mean.
I should also add that there are the four bolts holding the compressor to the support bracket that need to come out. I left my compressor hooked up to the A/C lines and sat it out of the way, then removed the bracket separately. Good luck
Old Jul 14, 2011 | 01:20 PM
rriddle3's Avatar
Follow these steps to pinpoint the source of the problem:
96+ Fuel System Diagnosis
Old Jul 14, 2011 | 02:48 PM
taabjb2010's Avatar
yes the that is correct the bracket where the ac fits and the pulley underneathe that
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
