fuel problems
Old Jun 15, 2009 | 09:56 PM
rokchippr's Avatar
rokchippr is on a distinguished road
Default fuel problems
I'm new to these s-10 blazers guys so please bare with me. I have a 2000 model 4 door w/4.3 . I was having problems running out of fuel if I let the tank get below 1/2 full. The truck would also act like it was starving for fuel if you accelerated hard. I changed the fuel pump and it fixed it for about a week and then the same problem of starvation at hard acceleration came back. Any thoughts or previos experience with these problems?
Old Jun 15, 2009 | 11:02 PM
What brand of pump did you use?
Have you connected a fuel pressure gauge and verified proper pressure (55-60psi key-on, engine-off)? If you get yourself a gauge, try to connect it and have it displayed somewhere that you can see it as you drive down the road when all of the other conditions are right for the problem to occur.
Old Jun 16, 2009 | 07:08 AM
rokchippr's Avatar
the pump brand was airtech or something. is the guage connection on the driver side of the engine ?
Old Jun 16, 2009 | 08:09 PM
It is on the fuel rail that is towards the driver side of the intake manifold. It should be readily visible. You will have to remove a cap prior to connecting the gauge.
Airtech pumps are not known for their reliability.
Old Jun 16, 2009 | 09:51 PM
Blazerdude01's Avatar
Blazerdude01 is on a distinguished road
Default Hey dude
sound like a simple prob. It has to be your fuel filter If not try this 1st put some injector cleaner in your tank if do not work change you fuel filter about $30 or so wish you luck let me know if this helps
95jblaze
Aug 27, 2011 03:46 PM
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
BlueLopez22
Apr 4, 2006 11:39 PM
chach3835
Engine & Internal
Feb 9, 2006 05:51 PM
