fuel pump
To find out if a pump is an exact match, go to Rockauto.com look up the part for your truck and click on part #. Popup shows other year/model fit
- Another problem is that sometime in the series, the elect connector changed and -assuming you still have the OE in there- you will need the new pigtail. It comes with a replacement pump.
If you get a junkyard pump and it doesnt say Delphi (OE) on it, I would pass on it. I dont think ACD replacements are labeled are they?
Also, look here:
NEW ORIGINAL AC DELCO FUEL PUMP MU113 MU1755 MU1063 | eBay
Also, look here:
yes i think there labeled on top where the hoses attach
i ended up pulling the 98 pump, quick and easy (cut a hole in the floor) and now have to drop the tank on mine tomorrow. shouldnt be too bad, its a 98 and they dont salt the roads here so its pretty rust free.
what brand pump
ac delco. im going to assume that it works as the blazer it came out of had front end damage and i would think it was probably moving when the the damage ocurred lol
the ac delco sticker was on a connector on the top of the sending unit, il check if there is anything on the pump
I suggest before bolting every thing up connect the pump and turn your ignition on and see if you can hear it if you do proceed putting every thing together
BouncingRadical
14
11-27-2015 12:30 AM
cide
11-07-2009 01:26 PM
upblazer95
03-08-2009 07:15 PM
mytruck2
12-13-2006 04:50 PM
