fuel pump electrical, maybe
Old Jun 2, 2013 | 08:46 PM
  #21
newguy's Avatar
pretty much dead center, next to pump relay when its blown theres no power to the Ignition module
Old Jun 2, 2013 | 09:02 PM
  #22
The pink wire at the ignition module has no voltage when it blows? If that's correct, check the pink wire at the following places and see if you have voltage when it blows:
Crankshaft position sensor
Fuel injector connector, (all 6 pink wires)
Ignition coil
Connector "C1" pin B10 at the PCM.
Ignition must be in the RUN position when checking for voltage on each of these circuits.
Old Jun 3, 2013 | 03:44 AM
  #23
newguy's Avatar
will do capn. Thanks
Old Jun 3, 2013 | 02:33 PM
  #24
If in fact it's the ECM 1 fuse that's blowing, the components in post #22 are the only things on that circuit, and that's where you'll find a short to ground, or excessive draw.
Old Jun 3, 2013 | 03:20 PM
  #25
newguy's Avatar
Ok, today I followed the pink wire (power right?) from the Ign. module to the crank. pos. sensor and found this. The loom was melted to the manifold and the pink wire was burnt/ melted also. here are 2 pics, kinda blurry but you can see the burn area a 1/2 inch above my hand. I believe this is it. Hit a bump it would blow. Sounds about right, ya think?
Attached Thumbnails fuel pump electrical, maybe-100_0565.jpg   fuel pump electrical, maybe-100_0566.jpg
Old Jun 3, 2013 | 05:27 PM
  #26
Bingo! That's it. The pink wires are individual, seperate wires that run directly from the underhood fuse panel, (each has its own pin on the underside of the fuse panel) to each of the components that I mentioned above. If any of those pink wires short to ground, the fuse will blow, (the exhaust manifold is ground). Repair the bare spot and reposition the harness away from the manifold.
Old Jun 3, 2013 | 05:55 PM
  #27
newguy's Avatar
Already done, drove it for a half hour hitting every bump I saw. Think I got it
Old Jun 4, 2013 | 02:18 PM
  #28
newguy's Avatar
Drove it all day today, all good
88s10Blazer
Jan 22, 2010 01:07 PM
Alex01tib
Mar 26, 2009 02:11 PM
xAnarChisTx
Jun 4, 2008 10:49 AM
alexedge
Apr 6, 2008 12:51 PM
USMaverick101
Nov 17, 2006 04:06 PM
