Fuel Pump Info
Old Nov 14, 2021 | 08:56 AM
poolbizz's Avatar
poolbizz is on a distinguished road
Default Fuel Pump Info
Can anyone answer if the Delphi FG0052 Fuel Module has a check valve. My 2001 Blazer 4.3 fuel pump went out . Thanks in advance
Old Nov 14, 2021 | 11:02 AM
GeorgeLG's Avatar
Every fuel pump on our trucks has to hold the line pressure after the pump energizes and so they all have some mechanism to prevent back flow into the tank. The pressure is also maintained at the other end of the line by the fuel pressure regulator at the intake end. You separate the two problems with the second part of the fuel pressure test at the fuel filter. Of course the fuel pump can fail by not pressurizing at all or insufficiently.
George
Old Nov 14, 2021 | 11:32 AM
poolbizz's Avatar
Thank You !!! I m doing both updated spider injectors and fuel Pump with FG0052 . The way its worded on Amazon is deceiving ... Again TY
sailorjohn
Oct 31, 2012 11:51 AM
Stuntman Mike
Jun 25, 2010 08:55 AM
masterrcs971
Feb 22, 2010 07:04 PM
kpmink
Nov 12, 2008 09:05 AM
chad177
Nov 15, 2007 12:49 AM
