Fuel Pump issues
Old Sep 4, 2016 | 05:52 PM
Travis Schneider's Avatar
Travis Schneider is on a distinguished road
If pump is running it's supposed to be pumping gas. I thought all lines to pump were different size tubes. I would run it with lines off but with rubber tubes into a gas can and see if it pumped gas. That's how I emptied my tank off test valve on motor.
Old Sep 4, 2016 | 08:02 PM
Originally Posted by Travis Schneider
I put 12v in the fuel pump relay slot top left it shorted. Was evacuating tank for pump replacement, pump is in it runs hot wired to pump test port but I can't find short for top left relay pin. Knowledge greatly appreciated. Edit 1999 blazer 4x4
Understanding I'm talking to myself while people watch however I may have shorted (hopefully) the fusible link to the ecm. I now don't know where that is. Any help greatly appreciated.
Edit found this pic under vcm issues, relay cluster https://blazerforum.com/forum/attach...l-img_2525.jpg
Old Sep 10, 2016 | 09:30 PM
Off an s10forum "Sorry I'm a little late on this topic, but a few weeks back I had a PCM go bad. I fried it when I tested the*fuel*pump by jumping the relay--only I got the pins backwards and jumped the PCM instead of the pump. As ridiculous as it sounds, I'm smarter than that. Usually." Eh it's only 200.00
Old Sep 11, 2016 | 04:07 PM
ThaGMan's Avatar
ThaGMan is on a distinguished road
I purchased a brand new Tank and Pump once,(they are a pain to put in). Finished install and Blazer would not run. Checked everything ( Always have someone listen for pump to actuate). In my case pump was in fact wired properly and working. After many complains to Vender it was discovered that there are actually two possible pumps for that Vehicle. I forgot which Blazer it was I have had 13 different years. That particular year had two possible pumps and you will not get the pressure you need unless proper pump is installed. Before you have to take that puppy out again dig into the proper pump for your Vehicle. Once Installed the proper Pump I never had a problem again.
Old Sep 11, 2016 | 06:41 PM
Forgot to mention the oil pressure switch controls gauges on some models. Mine was broken but barely connected I replaced it got gauges back as well. Pump won't run without it. But should be able to test it.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
