Fuel ups difficult
Old Jan 7, 2008 | 02:06 PM
lagnaf's Avatar
lagnaf is an unknown quantity at this point
Default Fuel ups difficult
Have an '01 4Dr. Just bought last week. Went to fill up with fuel. But no matter how you place the fuel nozzle in the tank. It wont take fuel unless it's trickling in.........
tried a different pump also..
Any Ideas????
Thanks,
Dan
Old Jan 7, 2008 | 08:07 PM
pbd3mon's Avatar
pbd3mon is an unknown quantity at this point
Default RE: Fuel ups difficult
Sounds like your tank is not venting properly. Check your vapor recircualtion lines to make sure they're not blocked. Do the same for your carbon canister, sometimes when the tank is overfilled past its rated capacity (force filled by slowly trickling fuel into the tank) liquid fuel gets into the canister causing a blockage. I believe the canister is located at the back on the left side just behind the left bumper end. One of the recirculation valves could be stuck in the closed position, try tapping the tank from the bottom and sides to release and open. I hope this helps.
j5689
Mar 27, 2010 12:56 AM
snosh
Sep 28, 2009 03:15 PM
Smoked
Feb 21, 2009 03:20 PM
lynnmcd
Apr 2, 2008 06:44 PM
harpes620
Dec 8, 2006 10:07 PM
