Fuse Question, I need help like yesterday!
Old Nov 21, 2008 | 09:14 PM
POS95Jimmy's Avatar
POS95Jimmy is an unknown quantity at this point
Default Fuse Question, I need help like yesterday!
My Jimmy keeps blowing the ECM BATT fuse, WTF is wrong? I need this thing running as it is my Daily Driver. Help!
Old Nov 23, 2008 | 07:31 PM
Default RE: Fuse Question, I need help like yesterday!
This fuse powers the fuel pump relay, the fuel pump oil pressure switch, and the ECM itself. You can try unplugging or removing (in the case of the fuel pump relay) all of them and installing a new fuse, then turning the key on to energize the circuit. If it blows, then the problem is in the wiring itself. If it is good, then plug them back in one at a time and turn the key on. If you go through all of them and the fuse still does not blow, then it may be a combination of things.
Here is the schematic for the fuel pump:
The only thing it does not show is the connection to the ECM, but that is the only other thing that is powered off of this fuse.
mudcat
May 29, 2011 03:19 PM
blznlowxtreme
Oct 10, 2007 04:49 PM
BLK85
Street N Strip
Oct 9, 2007 08:52 PM
Loud_01_Blazer
Oct 24, 2006 11:48 AM
88s10Blazer
Jul 24, 2006 02:11 PM
