FWD 4lo blinking
Old Jan 9, 2011 | 05:28 PM
texter's Avatar
texter is on a distinguished road
Default FWD 4lo blinking
Greetings! I have a second gen (2000) ls four door FWD blazer. The switch is a three button push. It appears that 4HI works as when I push it the light turns on and stays solid. However, when I push 4LO the 4HI light stays on and the 4Lo light just blinks (I assume this means that 4lo isn't working)
My question is two sided.
1. Is it safe for me to drive with 4HI on in the snow if 4Lo is not functioning?
2. What could be causing this issue?
Thanks!
Old Jan 9, 2011 | 07:13 PM
4x4blazerguy's Avatar
Are you trying to engage 4lo as per the owners manual? You need to have the transmission in neutral with the truck stopped or rolling very slow. You have to disengage the same way.
You have a 2000 Blazer 4x4 a FWD stands for (front wheel drive) Blazers are either RWD (rear wheel drive or 4x4)
Old Jan 9, 2011 | 07:19 PM
4LO is really for situations where traction is at a maximum and mechanical advantage (through gearing) is desired. For normal on-road driving, 4LO should not be used.
Old Jan 9, 2011 | 07:55 PM
texter's Avatar
Default Thank you
Thanks! I'll try to engage it as you mentioned. I'm going to use 4Hi through the snow. Just wanted to make sure that my 4WD is working before I drive with it and get it stuck in 4WD or something.
My pdf download of the owners manual is still on-going
kgkern01
Feb 17, 2012 10:56 AM
hambone8
Apr 14, 2010 01:20 PM
richjoe
Aug 21, 2009 07:07 AM
Paymeister
Performance & Brainstorming
Jun 26, 2008 08:30 PM
Lee
Mar 12, 2007 03:52 PM
