Gas tank venting problem
Old Sep 5, 2015 | 09:16 PM
Psiegrist1's Avatar
Psiegrist1 is on a distinguished road
Default Gas tank venting problem
Hello all. I have a 95 S10 Blazer that I use on my mail route. I start each day with a full tank of gas and lately after a couple hours into the route I have fuel leaking from the backside of the fuel filler neck area inside the fender. When I loosen the cap there is a big whoosh of air coming out of the tank. It's not the 2" filler hose that's leaking so it must be the smaller one immediately above it. Is this a vent line that has become plugged or something? I just figured out that if I don't tighten the cap it does not leak but don't want to do that for long. I'm stumped on this one.
Old Sep 6, 2015 | 08:43 AM
abig84's Avatar
if your vehicle has a vent valve it could be stuck closed causing it not to vent. also your charcoal canister can be filled with gas causing a similar situation
Old Sep 6, 2015 | 11:00 AM
someone11's Avatar
someone11 is on a distinguished road
The filler necks are known to rust ou and get a hole. Mine did. Also my blazer always has a "whoosh" when I open the cap.
makeminelgd
Feb 21, 2014 12:33 PM
wlorton
Feb 17, 2010 09:23 PM
Sisk
Oct 31, 2009 05:43 PM
mad_blazer
Suspension Tech
Oct 11, 2008 05:31 PM
94blueknight
Jan 6, 2008 01:53 PM
