Gasket At Throttle Body
Old Aug 19, 2019 | 05:51 PM
RTJ49's Avatar
RTJ49 is on a distinguished road
Default Gasket At Throttle Body
Hi All,
When I use a smoke machine to check for vacuum leaks I get a lot of smoke out of the top of the throttle body where the plastic cover is over the throttle body that leads to the air filter box. The large T nut is as tight as possible. Should there be a gasket/o-ring here? I have nothing.
Thanks,
RTJ49
Old Aug 19, 2019 | 06:40 PM
There is a seal built in to the plastic elbow. You can see it if you remove the elbow. They do wear out and, even though it's removable, it's not available separately. It's about 100 bucks to replace the whole elbow. If you've been thinking about a new cold air intake, this might be the time.
Old Aug 19, 2019 | 07:21 PM
RTJ49's Avatar
Thanks Tom
RTJ49
Old Aug 19, 2019 | 07:23 PM
No problem.
I just went through the same thing about two weeks ago, so I feel your pain.
ComputerNerdBD
Oct 3, 2022 01:34 AM
Rodney V
Oct 24, 2016 06:55 AM
myDownfall
Mar 27, 2011 10:01 PM
94camaro
Performance & Brainstorming
Dec 15, 2008 02:15 PM
FoxTrota
Apr 20, 2008 06:58 PM
