Grinding noise...wheel bearing?
Old Apr 2, 2012 | 01:12 PM
Colten's Avatar
Colten is on a distinguished road
Default Grinding noise...wheel bearing?
I recently drove on some rough dirt roads, and noticed a grinding sound shortly after. Sounds like a wheel bearing, but goes away at faster speeds. The only time I hear it is slowing down to stop or accelerating until I get back up to 10-15mph then it goes away again.
Feels a little rough when turning also, especially to the right.
My first thought was damaged wheel bearing, but I thought those normally made more noise at higher speeds.
Thanks for your help
Old Apr 2, 2012 | 01:30 PM
50lb_cat's Avatar
Sounds like a wheel bearing. Jack up the truck and grab the wheel and check for excessive play. Up and down and left and right.
Old Apr 2, 2012 | 05:37 PM
step66's Avatar
Yes-Hub and bearing assembly! Do both sides....
Old Apr 7, 2012 | 08:25 AM
Colten's Avatar
Default Seized Brake Caliper
Thanks for the help guys...actually ended up being a seized brake caliper. My question now is, looking around at some other threads I saw that sometimes a constricted brake line can cause a caliper to seize up. So when replacing the caliper should I also replace the brake line?
wicki5420
Jul 17, 2012 06:17 PM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
mkbermel
Jul 20, 2010 08:03 PM
dBsound
Mar 2, 2007 01:16 AM
