hard starting
Old Oct 30, 2010 | 11:23 PM
98jblaze's Avatar
98jblaze is an unknown quantity at this point
Default hard starting
hey guys i have a 98 4dr 4x4 i put in a fuel pump back in jan of 2010 ran great then about a month ago it started to take a while to start 2 days ago i put in a new fuel filter now when it starts it runs a little rough and is getting harder to start but after it runs it smooths out no power loss and then when i start it again hard to start please help thanks
Old Oct 31, 2010 | 08:43 AM
Have you verified that the fuel pressure is within spec and that it does not quickly leak down?
Old Oct 31, 2010 | 08:55 AM
98jblaze's Avatar
no i haven't going to get a pressure gauge tester today
Old Oct 31, 2010 | 08:57 AM
Let us know what you find. Sometimes, new pumps can expose weaknesses in other areas of the fuel system. In this case, you may have a leaking FPR.
Old Nov 2, 2010 | 09:42 PM
98jblaze's Avatar
i checked thr fuel pressure regulator and when i shut the truck off the pressure went from 60 to 0 in less then a min i guess this means i need to replace the fuel pressure reg can it be anything else i heard the spider injector can be bad too please help thanks
Old Nov 3, 2010 | 05:37 PM
96+ Fuel System Diagnosis
That should lead you to the defective component. It could be the FPR, but it also could be the check valve in the pump. There is a step in that procedure that will determine whether the check valve is seating or not.
Old Nov 3, 2010 | 07:40 PM
98jblaze's Avatar
thanks for your help my brother thinks it is getting to much fuel and flooding out he thinks thatbecause i turn the key on and the pressure goes to 60 and holds he thinks it is flooding out can that be possible
cgrett
Nov 15, 2010 09:08 PM
Texasmudder
Dec 29, 2006 01:09 PM
Icarus76
Aug 23, 2006 09:44 AM
HaRt
Jun 12, 2005 04:15 PM
tucker4982
Jun 7, 2005 05:33 PM
