Have egr problem. Need help
Old Jan 6, 2014 | 11:07 PM
Blazin chevy 13's Avatar
Blazin chevy 13 is on a distinguished road
Default Have egr problem. Need help
I have a 2000 chevy blazer ls 4.3 code for egr stuck in closed position popped up I removed the egr cleaned it thoroughly with carb and choke cleaner made sure it moved freely put back on with new gasket. About a day later cel showed up again with some code and one for ho2s bank 3 sensor 1 no activity. I found the o2 sensor had a disconnected wire. Going to replace that. But what should I do about egr? I don't have the cash to replace it at this time. Any advice? Thanks!
Old Jan 7, 2014 | 08:07 PM
cleburne red's Avatar
Just clean it really good, make sure there's no carbon in it, and that the pintle in there moves freely. Then, put one of these on: Help/2 pcs. GM 1992-2003 and Ford 1980-1993 EGR Clean Screen Gasket (47007) | EGR Gasket Screen | AutoZone.com Otherwise, unless you want to remove your manifold and surgically clean it, you will continue to have egr problems.
lockwoodjace
Jul 11, 2013 06:09 PM
RexCastle
Dec 3, 2012 10:15 PM
sebringflyer
Feb 21, 2010 07:30 PM
diggerdave
Jul 6, 2006 03:31 AM
