Head Gasket or Intake Gasket
Old 01-03-2008, 06:14 AM
Default RE: Head Gasket or Intake Gasket
I highly doubt that it is a blown headgasket if it is leaking externally. More likely is a failed intake manifold gasket. Head gasket failures usually result in coolant in the oil and/or coming out the exhaust.
Old 01-03-2008, 02:32 PM
4x4willywill is an unknown quantity at this point
if its leaking out without the engine running ... then imma guess a hose is gotta hole in it... check your heater hoses.
Old 01-03-2008, 02:55 PM
bigv is an unknown quantity at this point
I'm in Spokane. After researching a bit more, I think it is the intake gasket, so I'm going to start wrenching on it. I'd rather give it a try than pay someone.
Old 01-03-2008, 02:57 PM
i was kidding lol
Old 01-03-2008, 03:00 PM
I believe you are right - intake gasket. That intake gasket manual you sent from D-tips to armyboy back in October is great. I'm going to give it a go. Thanks for the info.
Old 01-03-2008, 03:11 PM
I was just typing up a reply that linked to it. I used that same procedure with great results on my old Bravada. Excellent write-up!
Old 01-04-2008, 10:15 PM
Yea, its definitly the intake gasket - fairly large blow out. I should have this done and up and running over the weekend. I am going with the new metal gasket type - it's more $$, but I've been told it'll hold up much longer than the rubber based gasket.
Old 01-04-2008, 10:17 PM
well, you were right about all the nuts and bolts - and then some!
limited edition 1
01-27-2023 11:07 AM
Melrock83
07-03-2012 06:51 AM
mylittletonkatruck
03-07-2012 02:04 PM
J.R. Clay
03-17-2011 08:22 PM
LJ809
04-25-2010 06:02 AM
Quick Reply: Head Gasket or Intake Gasket
