Headlights are Out. What do I check?
Old Jan 12, 2009 | 06:50 AM
steve8650's Avatar
steve8650 is an unknown quantity at this point
Default Headlights are Out. What do I check?
I have a 95 S-10 and the main headlights do not come on. The parking lamps do however. If you have ideas on things I should check and in what order that would be appreciated. If there are good links to see pictures of any things to check that would also be appreciated. I can work on different things but do not always know what they are called or where they are located.
I replaced a switch behind the dash last year for the blinkers and it took me many trials and errors to figure out where this was. It was not until I looked on the forum did I get good direction.
Thanks.
Old Jan 12, 2009 | 04:40 PM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
Default RE: Headlights are Out. What do I check?
first thing check the fuses... both of my headlights did the same thing and it was the fuses...
Old Jan 12, 2009 | 08:42 PM
steve8650's Avatar
I tried to check the ones I thought had to do with the headlights but they all checked out. My manual did not show a fuse specifically for the headlamps. They all seemed to be park lamps, rear lamps etc. All lights on the truck work with the exception of the headlights.
I thought maybe there was another place for the fuse but have not been able to find one. Also, have heard that maybe there is a relay however have not been able to find that either.
Any help in finding which fuse it is and where it is located or where the relay may be would be appreciated.
Thanks.
Old Jan 12, 2009 | 08:45 PM
PABlazer's Avatar
the relay should b in the fuse box under the hood.. and the fuse u r looking for is labeled on the underside to the fuse panel cover for under the hood... it should say somthing like L HL or R HL somthin alongthose lines
Old Jan 12, 2009 | 09:48 PM
steve8650's Avatar
I did end up finding what I think are the relays for the headlights in the back of the glove box. Since I did not have replacements I went ahead and changed out the light switch on the dash. I did end up fixing the problem. I now have headlights to go along with the parking and tail lights.
hollywoodgrad
Jan 25, 2012 01:58 PM
BlackBastard
Jul 7, 2011 11:31 PM
NJE_WDE
Feb 1, 2010 11:38 AM
Gerbraldy
Feb 2, 2008 11:09 AM
TheDesertFox
May 4, 2006 05:44 PM
