87 K5 all headlights out
Old Jan 31, 2010 | 01:16 PM
NJE_WDE's Avatar
NJE_WDE is on a distinguished road
Default 87 K5 all headlights out
yesterday all of my headlights stopped working, but all other lights on the switch work. Just wondering if anyone knew of a common problem that could have caused this.
Old Jan 31, 2010 | 01:31 PM
Fuse..?
Old Jan 31, 2010 | 09:40 PM
abig84's Avatar
someone stole your headlights!
if its not the fuse. you can check the power going out of the headlight switch. forgot what color it is. its obviously getting power if the tail lights work.
also kinda a stupid thing to try. try your brights switch. had one that was bad before and when you put the brights on you just lost all your headlights
Old Jan 31, 2010 | 10:49 PM
hubert hefner's Avatar
hubert hefner is on a distinguished road
do you have 4 headlights or 2?
Old Jan 31, 2010 | 11:28 PM
NJE_WDE's Avatar
i have 4, and i think it is the brights switch, is that hard to replace
Old Feb 1, 2010 | 07:39 AM
have to take the steering wheel off and work your way down to it. shouldn't be to hard to do. i've changed them in other cars before and they had air bag junk to mess with so im sure its gonna be pretty simple. Just go by the book should be pretty self explainatory.
Old Feb 1, 2010 | 11:38 AM
abig84's Avatar
I think your thinking of the lever. The actual switch is on the bottom of the steering column and is controlled by a bar from the lever. Ive only replaced one and the column was out so not really sure how hard it is to get at. But it should be on the driverside. I think its right next to the ignition switch. If you can get at it and have a test light shouldnt be hard to figure out if its bad
Eserps89
Jan 29, 2013 07:45 PM
hollywoodgrad
Jan 25, 2012 01:58 PM
ben97blazer
Oct 2, 2011 11:23 PM
Gerbraldy
Feb 2, 2008 11:09 AM
TheDesertFox
May 4, 2006 05:44 PM
