hellpp, coolant leak
Old 09-16-2011 | 08:47 AM
pd95blazer's Avatar
pd95blazer is on a distinguished road
Default hellpp, coolant leak
Ok I have a 95 blazer and to make a long story short I'm having water leaking from the back of the motor but can't pinpoint it its not the water pump or anything like that when I looked underneath it looked as if it was running down from somewhere I couldn't see and coming off of the trans bellhousing any ideas ? I'm thinking its the intake manifold gasket but would like another persons view I also hear a whine from the front of the motor sorry ahead of time if this post is in the wrong area just really need help
Old 09-16-2011 | 09:56 AM
TheRandom1's Avatar
Sounds like the head gasket to me. Or possibly a leaking line to your heater core. Does it seem to be leaking on the passenger side or the drivers side?
Old 09-16-2011 | 10:37 AM
pd95blazer's Avatar
Its leaking from the drivers side my oil isn't milky looking. I really hope its not the head gasket
Old 09-16-2011 | 10:52 AM
shade tree's Avatar
shade tree is on a distinguished road
Very good possibility that it is the lower intake manifold gasket. They are notorious for failing on the Vortec V6,usually at the coolant ports.
Old 09-16-2011 | 11:05 AM
pd95blazer's Avatar
Thanks Im hoping its that particular gasket going to get it home soon and try to see exactly what's going on... do you know of a way to test this theory?
Old 09-16-2011 | 11:17 AM
TheRandom1's Avatar
Put a UV dye in the coolant, run it a little bit so it cycles through, and use a UV flashlight on the wet areas. It can help you determine how high up the leak comes from, and possibly find the are it's coming from.
Old 09-16-2011 | 11:28 AM
dobyken's Avatar
dobyken is on a distinguished road
Maybe he's lucky and it's just his A/C drain...he did say it was leaking water and not coolant...then again..when are we ever lucky around here.
Old 09-16-2011 | 11:29 AM
TheRandom1's Avatar
That's on the passenger side if I'm not mistaken.
Old 09-16-2011 | 12:15 PM
rriddle3's Avatar
Originally Posted by pd95blazer
...I'm thinking its the intake manifold gasket...
Agreed, it's probably the lousy factory gasket GM used. Replace it with the correct Fel-Pro version and change the motor oil ASAP.
Old 09-16-2011 | 04:35 PM
pd95blazer's Avatar
When I pull this thing apart is there any way I can tell for sure this is the culprit
Quick Reply: hellpp, coolant leak
