Help. Burnt Rubber Hose
Old Dec 21, 2018 | 01:49 AM
Mikericord's Avatar
Mikericord is on a distinguished road
Default Help. Burnt Rubber Hose
So I have a 97 blazer 4x4 and i was driving down the road and started smelling rubber. I pulled over and looked under the truck and a rubber hose goin to the top of the transfer case from the front of the truck ( that was leaking fluid) was melting to the catalytic converter. I went to the autoparts store, bought a connector, and got it fixed, i just dont know what the hose goes to. Please help me understand whats it is. Thanks
Old Dec 21, 2018 | 05:30 AM
cleburne red's Avatar
Aren't there some vacuum lines that go to the tcase?
Old Dec 21, 2018 | 08:01 AM
Mikericord's Avatar
i think so. Only line i can visibly see is the one i had to fix
Old Dec 21, 2018 | 09:04 AM
Mikericord's Avatar
It might be the breather line
Old Dec 21, 2018 | 09:27 PM
odat's Avatar
None of the lines coming off the transfer case should have fluid in them. Check the fluid level in the transfer case if it's overfull you have a transfer case front seal leaking letting transmission fluid in...
David Thomas
Apr 30, 2018 02:57 AM
Mgern26
Nov 6, 2012 04:07 PM
griff763
May 29, 2011 10:02 AM
fahli
Mar 1, 2011 06:38 AM
guywm25
Dec 15, 2006 11:27 PM
