help finding new motor
It is just a crap shoot if you buy a used engine, no matter what the seller tells you. You may be buying some other persons headaches. It is better to buy a rebuilt engine from a reputable rebuilderunless you are trying togettheBlazer running just long enough tosell it.
Well I am just trying to get it running for the moment. It'll be a play toy I guess you'd say, I have a 92 explorer 2x4 and I'm tired of getting stuck lol. But that thing is my DD and I just need somthing better for mud. If the used motor doesend up being a lemon then I'll do the rebuild.I just need to know what year motor will drop right in now that I know a 2x4 will not thanks for that info Duntov.
So nobody knows whatyear blazer I can pull a 4.3 vortecfrom to go in my 95?? I've been searching but havn't come up with anything remotly usefull, maybe I havn't typed in the right words in my searches. If somone can help me out please chime in.
If you can find a 95 engine that would be best(obviously). There are 'some' emmissions stuff on a 95 that are not on a 94 although to the naked eye these vortecs look the same from 92-95. 96 is COMPLETELY different. I'm not 100% sure a 94 wouldn't work but again...the evap stuff is there on a 95 and in 94 there wasn't much of it and how much work you'd have to do I'm not sure-that is if it can be done at all. Sure it can be but...get a 95. Thats my 2 cents worth! JP[:'(]
To be sure of interchange, only purchase a 1995 engine with the sam casting number as your old one. Two of the1993-1994block casting numbers that were also used in 1995 are 10227196 and 10235359. Even if you purchase a 1995 engine, with one of those two numbers, a mid-year change in 1995 can cause problems that involve the front timing chain cover. The 1992 through early 1995 engine used a tall metal timing cover with ten bolt holes and the late 1995 timing cover was a plastic timing cover with eight bolt holes. If the block has ten front cover holes, you can use either the 1992-early 1995 tin timing cover or the late 1995 plastic timing cover. Do not use the early 1995 tin timing coverwith the late 1995 block that used a plastic cover because it will leak oil. Some 1995 blocks are drilled and tapped for a knock sensor and some are not. Most rebuilders will drill and tapp both holes for knock sensors so the hole will be where it is needed. Seewww.blainesmotorsupply.com for engines.
Jimmy Williams
02-16-2013 11:36 AM
ripintheuniverse
11-05-2012 02:20 PM
ely0569
03-15-2011 06:12 PM
