help! with fuel problem
i have 2001 chevy blazer 4.3 stanard trans. i put new fuej pump getting gtreat gas flow in bleed out valve put in 3sensors plus clucth safety swhich as long as i pour gas in throttle body it will run but stop pouring and it dies need to know how to fix it .are at least give me your thoughts on it .autozone said to pull out injectors see if gas is flowing but icannot find them if there is injectors where are they.
does the 2001 blazer have fuel injectors? blazer will start but not keep running. any ideas anyone?
Last edited by rriddle3; Feb 13, 2011 at 02:57 AM. Reason: COMBINING CONSECUTIVE POSTS
they are under the intake plenum. the black plastic thing that your throttle body bolts to ull also see the fuel lines and a huge electrical conector on top.. there is a fuel pressure regulator in there too. try replacing that it like 45 bucks. but first see how much fuel pressure yo have by putting a guage on it. put the guage on the shrader valve on the fuel line..
racinghoss
Sep 10, 2023 08:56 PM
vansoffthewall53
Sep 2, 2014 09:31 PM
95jblaze
Aug 27, 2011 03:46 PM
