Help i think my blazer is dying
#21
I have a 2000 blazer and after replacing spark plugs wires cap and rotor and injectors on that side i still have one whole side of the cylinders misfire it is the left side. It is getting a good spark i can not figure out it out any ideas
#23
Ok i finally tracked down a code reader the codes it is given me is p0304 cylinder number 4 misfire p0420 ignore that one i do not have a cat converter so it has always been on p0452 evap fuel pressure input low and it is giving me the p0304 code twice for some reason any ideas, and to those who told me to read the codes first and i said i know what code it would give me i am sorry i was wrong should have got the code reader sooner
#26
Yeah, that's low. Could be a valve or broken rings. Did you try putting some oil in through the plug hole and see if that improves your compression? If it does, the rings on that cylinder are shot.
You could also put air pressure to the cylinder when both valves are closed and listen for air either escaping from the exhaust, intake, or crankcase.
#28
Ok after two very exhausting days of taking that motor completely apart, (which after doing so I think I might have a personal vendetta against the guy who designed it) i found out it was indeed a bad valve in cylinder number 4. It was bent crooked, I had never seen anything like that, but anyway replaced it and it running good.
Hoythntr96
11-20-2014 05:30 PM
butters
02-07-2009 10:59 AM
ForkliftJeff
12-12-2007 10:08 PM
Wmac
05-07-2007 06:11 PM
