Highbeam problem
Highbeam problem
Just added some new highbeam bulbs. For some reason they are aimed up to high. The don't even light up the road like they should. I tried to angle the driver's side bulb down. But it didn't seem to do anything. Any suggestions????
RE: Highbeam problem
This may sound stupid but how do you remove the entire headlight asm?? it says in the book to remove the mounting screws?? where are they?
if you open the hood there should be a lil bolt at the top of the light to adjust the angle that the light shoots
Is there a way to completly remove the assembly?
There are adjustment screws. just loosen or tighten for the right angle
dusktiger
10-09-2014 11:12 PM
