Homemade Fuel Pump Bleed Off Tool!!
Old Jun 9, 2010 | 06:13 PM
What are you using to determine that the spark timing is retarded (after TDC)? Is the scanner giving you a negative number?
Old Jun 9, 2010 | 07:02 PM
Dan 128's Avatar
Dan 128 is on a distinguished road
Yes, with his scanner hooked up and reading and the motor at an idle, it displayed that the timing was at 12-17 degr. retarded, timing should be at 0 degr. (+ or -) 2 degrees.
Old Jun 9, 2010 | 07:14 PM
Well, I am not sure what scanner you have or how it is telling you that the spark advance is retarded, but most scan tools list it as spark advance. Positive values are advance. Negative values are retarded.
And there is no set value for ignition timing. It is controlled by the PCM and is variable.
Old Jun 9, 2010 | 08:06 PM
Dan 128's Avatar
Your right it did say (-) which is retarded and some 20 degr. different than what your motor was running and I'm having power issues, stumbling, stalling, backfireing, hesitation. All this happens if you try to throttle moderately hard or harder. If you baby the throttle up it'll run smooth????
Sometimes you have to punch it Margeret, but I can't or it will fall flat.
I'm not calling you Margeret just making some light of it.
monette999
Sep 7, 2013 11:52 AM
azzr2
Mar 25, 2012 04:19 PM
richphotos
Jan 5, 2012 07:46 PM
FirePhage
Jul 2, 2011 09:22 PM
Fault Bucket
Jul 23, 2006 04:26 PM
