hood release won't open help!
Old Nov 2, 2012 | 04:34 PM
newguy's Avatar
You dont even have to do all that, just look between the grill and the hood, you will see a ring that the hood release cable goes into, push that backwards with a flat head screw driver, and it will open, sounds like what happened to me, the table came out of that ring that holds it in the hood latch, was a easy fix.
depends on year
Old Nov 2, 2012 | 04:45 PM
richphotos's Avatar
Found this online.
If the cable isn't broken, have someone push down on the hood when the release is pulled, it should release. If it does, you should apply some lube to the latch mechinism to keep it freely working. If the cable is broken, you reach in behind the grille with a small hooked tool and find the cable going to the latch, hook the cable and pull it out 'this will take quite a bit of force' so you can grab it, you then remove the plastic housing and grab the steel cable with a pliers or other tool and from the latch side- pull hard to release the latch. you should then will have to replace the cable later. Also lube the latch.
stevie59
May 10, 2011 08:38 PM
sprbld417
Apr 25, 2011 07:28 PM
IRO
Dec 31, 2007 07:35 PM
Hanr3
Jan 22, 2007 02:30 AM
bat119
Jun 13, 2006 11:15 AM
