Horn doesn't work
Old 09-08-2010, 03:58 PM
mattjphoto's Avatar
mattjphoto is on a distinguished road
Default Horn doesn't work
Any ideas on what I should look for?
Old 09-08-2010, 04:03 PM
Benedict1337's Avatar
most likely a blown fuse. check your fuse box under the hood
Old 09-08-2010, 04:05 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if the fuse is good then disconect the horn and have some one else press the horn button and you should see 12 volts at the horn connnector
Old 09-08-2010, 05:43 PM
mattjphoto's Avatar
There are two things for the horn in the fuse box. I checked the simple fuse but I dont know how to get out the big guy to check it.
Old 09-08-2010, 05:47 PM
thats probally the horn relay, you can swap it with another realy of the same number and see it that works.
Old 09-08-2010, 05:54 PM
mattjphoto's Avatar
Does it just need to yank it out or does it use a tool b/c its in there pretty good.
Old 09-25-2010, 10:22 AM
knwollen's Avatar
knwollen is on a distinguished road
It just pulls out. Mine was good so I ended up pulling the air bag, follow all instructions to deactivate the air bag system. There are 4 screws in each corner holding down 4 copper plates, pull the plates out, hit them lightly with steel wool and turn them over and reinstall everything.
Old 09-25-2010, 10:56 AM
mattjphoto's Avatar
Thanks for the response knwollen but I ended up taking it back to the car dealer. Everything I looked at looked fine so I had no clue. Come to find out there was an aftermarket alarm installed and that was what was making the horn not work.
Old 10-27-2010, 06:41 AM
swiftb's Avatar
swiftb is on a distinguished road
my horn was working and now it stoped after I had an after market allarm put on last week..I have bought new horns from dealer and the alarm installers denies he is the problem what do I do ..Have them unistall the alarm? Help
lazer2000
09-16-2012 11:16 PM
raptorman
09-16-2012 02:10 PM
bubba14731
09-11-2012 01:48 PM
narftroz
01-19-2010 02:11 AM
degaine_designs
08-10-2009 02:50 AM
Quick Reply: Horn doesn't work
