how to disconect the fuse block?
Old Feb 17, 2009 | 02:23 PM
justin1795's Avatar
justin1795 is an unknown quantity at this point
Default how to disconect the fuse block?
ive got a 98 blazer and im pulling the motor. i wanted to disconect the main harness over the engine. i puppled the fuse block from the mount. i fliped it over and loosened the bolt and it begain to raise up. but even after the bolt was all the way loose it wont pull out. i tried the other ones and same thing so there must be a trick.
Old Feb 17, 2009 | 05:00 PM
Default RE: how to disconect the fuse block?
If the bolt is all the way loose, then you just have to pull. That is all there is. I used a small screw driver to help coax the connectors out.
Joann
Oct 14, 2013 10:33 AM
lil_blazin
May 10, 2009 05:20 PM
celchlepp
Nov 18, 2008 11:16 AM
rex
Apr 4, 2008 09:26 PM
navysar
Dec 5, 2005 04:20 PM
