How do i best repair/replace a door hinge?
Old Oct 31, 2017 | 04:04 PM
Jerika L Zuckerman's Avatar
Jerika L Zuckerman is on a distinguished road
Question How do i best repair/replace a door hinge?
the driver side door is one problem after another- the hinge was shot (when we got it) so the door was not aligned properly- needed to be slammed for it to close properly- needless to say a few slams too many- and the inner door latch busted out (the frame broke)- we had it re-welded- and thats fine but the hinge is still rusted and shot- door wobbles up and down
Aside from replacing my entire door- best option?
New hinges?
used hinges?
welding or adding something?
I will add photos to the comments soon!
Old Oct 31, 2017 | 04:17 PM
when closed
when closed
front of door- closed
upper hinge
lower hinge
NEW pin
upper hinge
HOLY MOLY! Sorry i dont know how to make the images smaller!!!
Old Oct 31, 2017 | 06:22 PM
New hinges?
used hinges?
I replaced my driver's door hinge pins and bushings. I had to get a tool to do it. Do you think if the bushings and pins were replaced it would align properly?
I ask because it looks like the upper hinge has a part that is about to break off which would mean either replacement or fixing with an uncertainty in its alignment. Also if the striker plate is misaligned it would be hard to fix it at all.
Christine
Old Nov 1, 2017 | 11:17 AM
There should be replacement hinges which use bolts instead of being welded on. Could also be welded.
I had a pair ordered on rockauto but used just the door side and the pin.
Old Nov 1, 2017 | 11:25 AM
Default replacement door hinges
What do you know, Rockauto does have replacement door hinges! http://www.rockauto.com/info/42/38705-007__ra_p.jpg
Nice to know they exist and are available. Only the front drivers door though. Then again that is the one that gets the most use.
Old Nov 2, 2017 | 05:24 AM
Christine
The hinge pins are new as are the bushings- didn't help
Old Nov 2, 2017 | 05:27 AM
i was reading not so great things about replacement hinges- i wanted to try to get some feedback from people who have done that or repair- i keep trying to find info but obviously the hinge places seem to think its just fine
My neighbor is happy to help me try to weld- but would that work?
Old Nov 2, 2017 | 05:51 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
New pins and bushings won't help if the holes in the hinges themselves are oversized or out-of-round. What I did when I made the same repair on my wife's '00 Blazer was to put some quick-setting JB Weld around the holes in the hinges to get them back to their original size before installing the bushings. That way, the holes in the hinges will be restored to normal size so the bushings won't be unsupported. It looks from the condition of the bushings that maybe the holes in the hinges had worn oversized and the bushings began to break down. If that's the case, redo the bushings and pins and build up the difference between the bushings and the oversized holes with plenty of JB Weld and the hinges will be good as new.
Old Nov 3, 2017 | 06:46 AM
From the pictures I would either weld (and that means fabricating parts) or get a replacement and weld or bolt that in place, or cut the hinge part and weld to existing support.
The OEM hinges are welded to the doors and to the frame and the pin and respective bushings act as the hinge.
Your's look shot (at least the upper one). The upper support of the pin is broken. Both bushings are shot. The door has an alignment issue which could be explained by the upper hinge being damaged.
The other issue is the lock side which broke ou of the frame. What has happened to that door?
The weld looks suspicious to me. Could be a torch weld which could explain why it broke at the edge of the weld.
All could be indicative of a hinge problem. The excess clearance makes the door sag. It will also damage the color on the lower part. (Fix it or it will rust your door away)
At the same time a quite high load of the doors weight in addition to rattling (clearance) while driving could have damaged the lock side.
This IMHO will need a pro fix as in properly fixed or more damage will follow.
r_marczak_83
Feb 14, 2013 05:27 AM
fondo
Jun 26, 2010 09:44 PM
saxy37
Apr 25, 2006 01:22 PM
hstt
Mar 4, 2006 12:03 AM
tomsblazer
Dec 19, 2005 03:46 AM
